2012 Ibiza FR drivers window
Nov 9, 2024
Hi, searched but couldn’t find anything so apologies if this has already been asked.
drivers window switch stopped working, replaced the switch but still not working so guessing it must be something more serious.
neither the driver or passenger window work with the switch on drivers door, passenger window is fine from the passenger door switch. From the button on the key passenger window rolls up and down but lot drivers. Central locking and mirror controls are both ok.
obdeleven doesn’t show any faults and fuses ok.
Any ideas of where else to look? Is it likely to be a BCM issue or wiring?
thanks in advance
ChriskiB
11
Ive just got the same issue, my drivers side window no longer works, just randomly stopped working, my folding mirror on the drivers side also isnt working, i can hear a click sound when the button is pressed up or down so im suspecting the motor deing dead. Part numbers can de different so it may be best to nip the door card off and remove the motor for the part number then buy the same replacement part.
Ive fitted the folding mirrors from a 6j cupra to my fr so im looking for this part 6R0.959.802.A
Hope you get it sorted if you haven't already.
Hi mate, what's the process for fitting folding mirrors? do they just take a port on the new motor and work once coded?
