Hi guys,
1.4TSi 2018 SC FR with electronic brake.
Rear drivers side caliper was sticking. Took everything apart to find the pads were non existent. Thought the pad and rotor would be fusing. Did pads and rotors all round and thought it might have been the fix. Problem came back.
Had a look again today, greased everything up, made sure the caliper piston was moving. While it’s hard to push back in by hand (it should be right?) it came out no problem. Put everything back together, made sure it was bled which wasn’t needed, made sure brake fluid reservoir wasn’t over filled, but still have the same caliper sticking.
however, while the electronic brake service option is open, the car rolls fine/better. So I believe it’s the actual brake servo. I did get a message of “brake servo restricted” when it was opened via Carista, but at the time i thought that might have just been an error thrown due to it being opened.
im now thinking of changing the caliper along with the motor, but can not for the life of me find a 253mm caliper with the brake servo. Is it possible that the 272mm one fits? I can find loads of those.
Any help would be appreciated.
