Better sound on the speakers
Oct 28, 2024
26
I find the sound on the cupra leon '21 (no beats) not bad at all, but coming from "premium systems" from Denon,JBL and B&O it just miss some punchy beats and low bass. Also, when turning the volume up it is a little bit hoarse.
I went to the audioshop and they advice me a DSP amp and a active sub in the trunk. They said the stock cupra speakers are quiet well already and no need to replace.
Do you guys know if the stock speakers should be better with a DSP behind it?
Never hears about a DSP so for me it is new.
Jul 31, 2024
The woofers need replacing, they are paper cone that flexes easily, see the post I just did https://www.seatcupra.net/forums/threads/st-vze-audio-upgrade-with-a-sub.477458/
if anything replace the speakers and NOT a DSP amp.... when I had the R2 front stage off the factory headunit it was much tighter and punchier, but a sub makes all the difference, underfloor will fit easily
Oct 28, 2024
26
Where did you place the sub? In my car is too less space below the floor in the trunk.
There is a fueltank...
Our audio car hifi seller say that the stock speakers in the HPEV are good enough. A dsp made it much crispier and louder, he said
