Seat Leon 1.8 intermittent dying whilst driving.
Oct 24, 2024
Hello all, Firstly I don't use forums often so if this is the wrong place to post I apologize.
I have an old 2002 Seat Leon 1.8 petrol that has been misfiring and dying whilst driving and it is not giving me any fault codes, It starts back up again after coming to a stop but the issue seems to happen at the same driving distance there is a certain road that every time would misfire and slowly die before coming back to life, The issue is it now is simply dying, (makes me think it could be a sensor that activates after a certain temperature or another metric is met).
It had a new battery and alternator and a full service recently before this issue came up.
I am just wondering if this is a common issue that can be fixed, or if the old girl needs scrapping as the rest of the car is pretty immaculate which would be a shame.
Happy to answer any questions you may have
Alexis27
2,187
515
Manchester
Things like that usually come down to fuel, air and ignition.
Maybe fuel pump, maybe spark plugs, maybe coils.
You could always take it to a garage instead of the scrap man 😆
nd-photo.nl
4,195
347
The Netherlands
youtube.com
Check the crank position sensor, its in the front of the block. My cupra would just intermittently cut out and was hard/unable to start. A faulty sensor will cut the fuel pump without any error message (safety mechanism).
The rubber hose was my PCV vent to atmosphere hose :)
New vs old (and dirty)
TJW92
Hi. I had a similar issue on my 2002 1.8 20v non turbo after I had the Air Flow Meter replaced for a non OEM one. When car was being driven was OK, but as soon as I stopped would cut out. I got a free replacement but same issue occurred after 6 months, so I purchased a used one, genuine Bosch version off ebay, gave it a good clean and has been fine ever since. It may not be exactly same issue but sounded similar.
