5F Pre FL with FL Bumper
João
Hey guys!
Im doing this topic since i cant find it anywhere.
Im starting to see a few leons 5f pre FL with FL bumper, and they look much better!
My question is, is possible to directly swap them?
I have some people that say, "yeah straigh swap, lights are different but just internal design etc, their dimension are the same", others say "no, you need to change lights and hood in order to do it".
Anyone already done that?
This is bumper im refering to.
Thanksss
  • brussels-belgium-jan-2020-seat-leon-brussels-motor-show-third-generation-facelift-typ-5f-hatch...jpg
Craig.
The artist formally known as ViperSlider
Mar 26, 2024
243
200
Cardiff, S.Wales
If you want to change the bumper then the bonnet (hood) needs to be changed too based on part numbers. I believe the grill is a different shape so the bonnet is a different shape in the middle but I've yet to confirm that in person.
Wings are the same and the lights shouldn't matter as I've seen PFL lights on a FL car. Or was it FL lights on a PFL car.... Either way, I've seen the lights are interchangeable physically but require additional work.
I'll be doing this myself in the near future so I've looked into it at a reasonable depth.
Craig.
Mar 26, 2024
243
200
Cardiff, S.Wales
Do you then upgrade to the 4B control unit or do you keep the 55?
There are significant electrical differences between the PFL and FL headlights including wiring and control modules but physically they can be swapped.
Getting them working is an entirely different circus ha!
cairus
1,062
363
So, I misunderstood that, it was just about the shape and whether it fits. Yes, electrically it's a lot of work. I would then convert the gateway to 3Q and the BCM to FL generation. Or do you leave the headlights VfL?
Craig.
Mar 26, 2024
243
200
Cardiff, S.Wales
In my case I will be changing to FL headlights but OP should be able to stick with the vFL lights without issue if they just want to do a bumper swap.
The FL headlights are an improvement over the vFL lights from what owners have said when they go from a vFL car to a FL car. Personally I find the vFL headlights to be adequate at night.
SRGTD
2,640
1,487
Don’t overlook the fact that changing the bumper (and bonnet / headlights?) to those on the later facelift car is technically a cosmetic modification. If you check the small print in your insurance policy you’ll probably find there’s something in the small print that requires you to advise your insurance company of any modifications. If you fail to do so and you’re then unfortunate enough to need to claim on your insurance, it could affect the outcome of the claim.
Additionally, if you sustain frontal damage and the insurance company is unaware a pre-FL car has a FL bumper / bonnet / headlamps, if those parts are damaged and need replacing, the replacement parts may be pre-FL parts.
Reactions: tracktoy
