Leon Mk3 shakes on full stop D, but not in N ?
Sep 22, 2024
Hi everyone,
Just got a 2019 Leon 2.0 and I noticed that while I come to a full stop the car shakes slightly, it feels like the clutch is engaged for some reason.
This happens with auto-hold either on or off.
When I shift the lever to Neutral, the shaking stops.
As far as I know, on full stop the clutches should be disengaged completely.
I shall mention that the car is tuned with SLS stage 2, and start-stop option was coded off. Could this be related?
Please share your wisdom, I'm scared for my clutches health
Thanks!
Mo_86
202
66
UK
In traffic when in D my car doesn't shake but u can hear the engine as if the revs a slightly higher than normal, when i put it into N it then goes away.
Btw is your start stop now fully disabled as i thought it couldn't be done on the facelift?
Legojon
I only wanted a remap
5,309
2,739
If you touch the accelerator with the handbrake on to raise the revs, does the shaking stop? Does it shake in park also?
H Rafiq
1,106
446
My DSG Cupra 280 does this intermittently in P and N. Engine judders for a couple of secs and revs bounce up n down, then back to normal again. A couple of times, as I’ve pulled up to a junction or lights to stop, the car has actually stalled… Thoughts? (See below error codes). It’s been in for new cam solenoid magnets n diagnosis here n there but couldn’t get to the bottom of it.
Sep 22, 2024
My revs are the same in D and in N, but in D the car shakes for some reason
Start-Stop was fully disabled by coding
I can't raise my revs on D without actually driving :\
In P and N I don't get the shakes at all
Well this sounds like a different issue tbh
I will ask my local garage about this on the next maintenance
cuthound
49
25
Sounds like clutch drag if it only shudders in drive and not neutral or park.
