Antera
Retrofitting Travel assist Seat Leon KL
Sep 1, 2023
20
if you want to have the capacitive functions, you also need a steering wheel with capacitive detection
Already but what I was referring to is if I activate it everything works the trip shaking the steering wheel from time to time or I wouldn't let the travel activate by not having the button on the steering wheel, I say it because I always carry it with the lane but if on the highway route I can activate the trip to a without having capacitive steering wheel
cairus
556
175
You need the capacitive steering wheel and the button for the system to work properly. What software does your assistant camera have?
Sep 1, 2023
20
Mine is the fr go L has front rear sensors plus camera in fact it has the lane asis as standard if I put it in early the car drives only perfectly the only thing is that it tells me every 40 seconds more or less take the steering wheel that's why I want to put the travel so that the lane goes as standard and the travel that goes in the center but of course I need to know without putting the steering wheel there is a possibility of activating the travel or I have to put steering wheel because I don't know if it can be activated with the same key that has my steering wheel
Sep 1, 2023
20
What does your car key have to do with the steering wheel? Nothing.
Te lo digo en español por que el traductor no traduce bien, yo tengo un SEAT leon FR GO L del 2022 mk4 tiene de serie el lane asis y lo puse en temprano y conduce solo a la perfección pero es molesto cada 50 segundos que mueva el volante por que no es capacitivo entonces quiero activar el travel pero mi volante no lleva la tecla del travel entonces no sé si se puede activar el travel y cada cierto tiempo menear el volante como el lane entonces lo activo en movimiento puntuales pero no sé si hay posibilidad o al no tener el volante no hay posibilidad
cairus
556
175
hay más que eso. Necesitas el volante capacitivo. Se debe adaptar la unidad de llaves con la llave del asistente de viaje y la codificación.
Sep 1, 2023
20
El problema es el idioma que no traduce bien yo no digo nada de llave,
Yo lo que pregunto es que si se puede activar el travel asist sin volante capacitivo ya que el coche trae el lane asist y quiero poner el travel sin volante pero no sé si al no tener la tecla del travel se puede activar, ya que de serie trae el lane
KoNG
515
108
London
Not possible to activate without touch steering wheel. But if you replace it its easy to code it with OBD11. Definitely worth the money you spent on new steering wheel
cairus
556
175
Entonces, para la función de viaje necesita: 1) un volante capacitivo 2) un botón para la función de viaje. 3) Es necesario adaptar los dispositivos de control.
