So if I do this, it would work? It should go back as before?
As I said, these are factory settings, so yes, these settings should put things back to working perfectly
Note edit - I have added all the channels for main beam left and right too, so you have a full record of the correct coding for dipped and main headlights and DRL strips
Reactions: albanjashari
So if I am right if I follow the steps on the pictures you send it would go back to factory.
