Washer pump gone help
Leonfrdiesel184
134
26
Hi everyone I think my washer pump has gone. No sound coming at all. Has happened intermittently before but seem to clear itself. Fuse seems ok, did notice washer reservoir was completely empty which wouldnt have helped. I have scanned the car with no fault code on the pump showing. I just wondered if anyone could help with a part number for the pump so I can order and how easy are they to replace. Instructions would be most appreciated, can you replace it without taking the wheel off? Thanks so much everyone.
H Rafiq
1,167
492
I don’t mean to insult, have you tried putting fluid in if it’s empty, and trying it? I know you’ve said you can’t hear the pump activating.
Leonfrdiesel184
134
26
Hi mate hope your well no insult at all It was completely empty and filled up last night but only had chance to check this morning and there is no difference mate. Normally though you would still here the pump when your washer is low though wouldnt you ? Thanks mate
H Rafiq
1,167
492
Yeah, you would. Sounds like pumps failed. And you’ve said the fuse is okay, so it’s not that. Looks like it’s a relatively cheape part, £5-30 on Autodoc.
This may help:
Reactions: Leonfrdiesel184
Cainy1989
89
40
Given that you might need to replace the pump you could retrofit the low level sensor while you're at it, I don't know why these all didn't come with one! Check the fuse for it first before you go ordering parts - Fuse 19 in the engine bay
Edit - sorry I missed the part about the fuse
Leonfrdiesel184
134
26
Thanks mate I could see a setting on obd and when I turned it on it kept saying washer level low so obviously like you say it doesnt have it. Any idea what involved to add this sensor mate ? Cheers again
Leonfrdiesel184
134
26
Update randomly started working again I can only assume it was because the water level was low but will keep an eye on it and see what happens. Cheers everyone
Reactions: H Rafiq
Jason2023
47
16
Sorry to mug this post re you comment on the low level sensor do you know if it can it be be done on a preface lift Leon ?
