Spark plugs
Mobbs69
103
13
55
Northamptonshire
I cannot remember the ones I had but i did have a little issue in fitting them.
When removing the coil packs there is a wire that you need to unbolt first before undoing the next nut to remove the coil pack
Just make sure you have a spanner on the nut on top as well as the one below it. I actually had to take one of my spanners and grind it down a bit so it coulds slide onto the bottom nut
I went a bit ham fisted on the first one with just one spanner and the bolt I thought was captive in the head wasn't. It twisted and I actually snapped the wire by accident
Bit of soldering was needed and its all good now but best to know beforehand
Phil th Barrow
13
Can any one help please... When/miles you should change the plugs on a Leon EX LUX 190 2.0... Are the original 3 pronged/earth??
SuperV8
1,545
685
Spark plug for DKZA, DNUE, CJXC, CJXH, CJXE, CJXG, CJXH,DNUC, 2.0
= 06K905601L which is NGK
every 60,000 km/48 months
SuperV8
1,545
685
No,
Just searching on the part number I shared:
NGK part number version = NGK 91898
Trade number ILFER7C8EG
Reactions: mty12345
tracktoy
584
400
Personally I use NGK R7438-9 Racing Spark Plugs and very happy with the fit and performance but It should be noted my motor spends more time on the track than on the road.
Reactions: Mo_86
