MIB1 5F Maps Update Issue and Missing Original Data Backup
May 27, 2024
Hi everyone,
I recently attempted to update my MIB1 maps on Seat Leon 5F SC to the 2020 version using the SD card. Unfortunately, the update didn't work as planned, and in the process, I deleted the original data on my SD card. As a result, I'm currently without any functional maps, and I’m quite stuck.
From what I've read in other threads, it seems that having a backup of the original MIB1 Europa V3 5F0.919.866E data should help resolve this issue. Therefore, I'm kindly asking if anyone would be able to share a backup of this specific version with me.
Any help or guidance on how to restore my system would be greatly appreciated. Thank you in advance for your support!
LeylandVCDS
494
287
Leyland, Lancashire
MIB1 maps can't be updated using later maps, it's only MIB2 that can be updated that way.
If you can wait a couple of hours whilst it uploads to my Google drive, I can let you have a full copy of the V5 Europa maps 5F0.919.866H which should work without any issues - this map worked well in my previous 2014 Leon with MIB. It should be ready at about 9pm (UK time)
Reactions: Mr Pig
Apr 29, 2024
lylandVCDS I have exactly the same problem, I tried to update but no avail.. I am stuck without maps MIB1 from 2013... Would you mind sharing the file with me too? 🥹
LeylandVCDS
494
287
Leyland, Lancashire
No problem, send private message with your email address
Do you have an ORIGINAL GENUINE SEAT SD card? You WILL need a genuine SD card for the maps to work. You cannot use any other than a genuine SD card even with the correct maps and files
Reactions: Mr Pig
Jun 3, 2024
@LeylandVCDS I am in desperate need for the original data since I destroyed the one on my Seat one. I have a Leon with the MIB1 from 2014 and I have the Europe V6. I'd like to try if the overall.nds file works for me. Thank you in advance.
SirBeans
LeylandVCDS
494
287
Leyland, Lancashire
SirBeans
Send me PM with your email address
The overall.nds file is not part of the MIB1 maps. That file is only on the MIB2 maps so does not apply
Dear LeylandVCDS,
Can you also send to me?
I have MiB1 on MK7 Golf.... File that I use now is P94_N60S3MIBS2_EU_NT ... this is from 2020/2021...
On VW site I cannot find maps for my device. Downloaded few different!
May 27, 2024
Just to let everybody know... I have finally found a solution to my idiotic file deletion without backuption. I just installed an Android Auto and CarPlay unit into my Seat Leon mk3 and it was the best decision i could have made. Maps are fully working and are up to date.
Nov 28, 2024
I lost the data too.
Some one can help me ?
