Head lights issues
Apr 6, 2024
Hey, I'm new to this but I'll make it quick.
So, I own a 2020 Seat Leon FR, 5F generation, with multi-LED headlights. In the past few days, I've had some problems with it. It all started when some condensation got into the headlight due to rainy weather. The car showed me multiple faults like range control fault or signal not working. Sometimes it shows vehicle light error, and the headlights went off just for a moment. But after restarting the car after a while, it went back to normal. Do you guys know what might be the problem?
mty12345
4,040
644
bristol
Probably just the water shorting something out, then when it dried it went away. Will probably be ok if it's gone away now.
Aug 16, 2024
13
Hi im currently having this same issue with my car there was alot of condensation in my headlight drl stopped working but satrted working again now im getting error headlight range control and please check front left turn signal any ideas what it could be and how to fix?
RWP
Jan 4, 2022
I had this issue also... But ended up having to replace the whole headlight unit because when it eventually failed it also started affecting the other headlight
Aug 16, 2024
13
Did your whole headlight stop working? And did you have to code the new headlight in to the car and what did you pay on the headlight?
RWP
Jan 4, 2022
The headlight with condensation did stop completely, but the other ended up being OK once the broken one was unplugged.
I bought a breakers one off ebay for £600. I made sure it had complete and unbroken mounting clips and the ballast attached.
I don't believe any coding was required though I could be wrong as I had a local mechanic perform the replacement.
Pinky
206
15
I've also got the condensation and faulty light problem. Currently the offside one has full beam stuck on, the DRL is flashing and no indicator. On Weds, it was fine when I popped out but started playing up on the way back. Flickering on/off like a low hz strobe. Yesterday it didn't work at all.
Aug 16, 2024
13
Same thing happening with mine was okay for about a week just the error messages but full headlight was working now its stopped working completely. When getting a new headlight do the part number for the headlight have to match with the current headlight in my vehicle does anybody know?
Pinky
206
15
Worked normally yesterday when I started it to move it. (Been sitting on drive since 3rd Jan). Then it went faulty again but not the same as before. Full beam no longer on. It's a different combo each time. 🤔
