Evening all,
Anyone got any experience or knowledge regarding the LED modules that control the headlights on a facelift Leon? I have purchased a damaged Leon which had 1 headlight missing, I've purchased a headlight and an LED module with the same part number but the new headlight is in emergency mode, so no DRL, indicator or main beam.
I understand this is because the module needs adapting, but not sure how this is done. Is this something done via VCDS? Also, are left and right headlights coded differently or will the new headlight module need to be the same as each other?
