Rims query
georgemilev
20
Hello,
I would like to get a second pair of rims and i got my eye on Autec Wizards 19 inch. They have two different sizes for 19 inch - 8j et 35 / 8 j et et 48, i was not able to find any thread if the et 35 will rub into the fender, car is not lowered now, but in the feature i am considering to lower it a little bit either with eibach / hr.
Thank you.
serdar_18fr
427
Hello,
Thank you.
"Compared to your existing wheel, this new wheel will have an inner rim which is 9.7mm further away from the suspension strut. The outer rim will poke out 22.4mm more than before."
I used 7.5x18 ET 51 factory installed rims for current setup. Other rim sizes used by the factory should approximately give the same result.
Sent from my 23013PC75G using Tapatalk
