Here you go:
Hi Has anyone managed to manually update an Mib3 system yet, I have a 2020 year UK Kodiaq but the update does not seem to work yet. I thought I read there was a software update to allow manual map updates but does not look like it has happened. I have not subscribed to the Skoda connect services ...
www.briskoda.net
I realise this is a long time after the original post, but having finally got the maps on my 2021 Octavia mk IV updated manually, I thought I'd share the process. My SatNav system is Columbus MIB3. For context...
The Skoda salesman who sold me the car told me I could update maps manually, but I'd tried following the instructions on the Skoda update portal and got nowhere. I'd downloaded the maps (Central Europe) onto a 64gb USB c stick and inserted it into one of the ports by the gear stick. I left it in the car for several days, and nothing happened. The car was due to have some warranty work done, so I thought I'd take the USB stick and get the garage to upload the maps for me. When I collected the car, the service reception told me I needed a subscription, based on what their 'master technician' had told them. I made the point that I'd been given different information from the salesman, who just happened to be passing. He re-iterated that I did not require a subscription, took my USB stick, and returned 5 minutes later saying "All done!". So I asked him how he did it, and subsequently played with the system to see if I could do the same myself.
Step 1 - press and hold the menu button until you get the page showing "software/update".
Step 2 - Select option "software/update"
Step 3 - press "start update". Wait a few seconds, while the screen goes blank, and then enters "engineering" screen.
Step 4 - select "update", then select which USB port to take data from.
This should trigger the start of uploading of new maps data. The file is about 28gb (Central Europe), but 64gb drive recommended. I'm not sure how long the process took, the salesman said it should be completed by the time I got home - about 40 minutes. My maps version has gone from 20/07 to 22/12 which is supposed to be 2023/2024 maps, so it was indeed completed pretty quickly. It helps if you have a high speed USB stick, which reduces the data transfer time significantly.
Hope this helps...
