Hi all,
Just wanted to write a post regarding the brake discs on the Cupra R ST. Mine have done 25,000 miles and were due another pad change but the discs were heavily scored. Rather than shell out the ~£700 for new discs I decided to go down the disc skimming route. I used a company in Manchester called Advanced Motorcare ltd and they did a great job. Cost £200 for both front discs skimmed+£60 labour for removal and refit of calipers. Would thoroughly recommend going down this route if you are in the same situation or if it is time to change pads and you want to improve braking performance and avoid brake squeal.
www.advancedmotorcare.co.uk
Stuart
Brake Disc Skimming
In-situ brake disc skimming. Correct poor braking, juddering and extend the life of existing brake discs.
Stuart
