Hi Guys - My son has an issue with his 184TDI
The EML and the flashing glow plug light are on. Car is in limp mode.
Code read is
5244 - Fuel Pressure Sensor ( G247 )
P0193 00 ( 175 ) - Short to plus
MIL ON - confirmed
We have changed the fuel pressure sensor - still same issue
We have tested the fuel pressure sensor plug connections ( battery voltage was 12.65v ) - ignition on - engine NOT running
Pin 1 to battery positive - measured 7.65v ( should be battery voltage )
Pin 2 to ground - measured 5v ( should be battery voltage )
Pin 3 to ground - measured 0.01v ( should be 5v )
We have tested all three wires from the Fuel pressure sensor back to the ecu - no shorts and all show continuity.
Has anyone had a similar issue and what fixed it ?
We were hoping to find an issue with the wires or connectors.
Code read is
MIL ON - confirmed
