One of the issues I think is the units the scientists are using in predicting temperature change - like one or two degrees global average warning means bugger all to most people - thinking so what!On climate change and the rest,
You can measure yourself how much co2 is in your local atmosphere.
Here's a speriment for you to do.
Get co2 meter, go into the garage, shut the door and measure the concentration write it down.
Run the engine in the garage for 30 mins and take another reading. You can then see what your car can do to a relatively small volume.
Co2 can be measured historically from ice cores and others so actual we not only know how much co2 there is but also how much there was.
Breakdown of carbon dioxide, methane, and nitrous oxide emissions by sector
How much do electricity, transport, and land use contribute to different greenhouse gas emissions?ourworldindata.org
Here's a good source of all sorts of stats.
Acid rain was a thing, another thing was done and now it's not.
The hole in the ozone layer, again an actual thing, the cause identified, the way we did things was changed and now the hole is very much smaller and shrinking.
All these things are researchable while you're sat on the toilet. Actual science is available to all who can understand it.
It is problematic however that much of science requires understanding and that many people don't have let's say a science brain.
The COVID thing is a case in point, the ppl with degrees and experience try to give ppl with a limited grasp of anything scientific information to decide the right course of action.
A herd of ppl is a daft unpredictable thing, get one person and you can usually get the message across. Usually
A very interesting stat I herd which helped me conceptualise it, from a climate scientists was something like (don't quote me) - the last time the earth was in an ice age when the oceans were frozen over, the average temperature was ONLY 5 degree cooler! so yes only a few degrees average global temperature change can have very big effects.
Also found 'potholer54' YouTube channel very interesting
