Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Just went and try to get the car Aircon re-gas. But was told the there is a leak and pump/compressor not working. Anyone know how much is it to fix roughly?
I believe that if there is a leak, ie. low or no gas then the compressor is shut off anyway, so the compressor may not be at fault. They should do a leak test first, unless this has already been done and they have established the compressor is leaking.
How I was explained, they did a re-gas checked and say the pump needs to be replaced actually. I'm not technical but is compressor and pump the same thing?
A new genuine AC compressor is £800+
Seems like there are aftermarket versions for more like £150-£200 depending on brand.
Did they show you the leak from the compressor? Think I'd want to see the actual leak first.
I feel that it is "horses for courses" ie maybe use a proper car air con specialist to find out the problem, rather than let a car mechanic taking a calculated guess.
I believe if a leak is suspected - they would add a dye to your system - and then check in week or so later to see evidence of where this dye?
Has this been done?
I would suggest the condenser (thin radiator looking part - in front of your actual radiator behind you bumper) would be the most common cause of air conditioning refrigerant leaks due to damage or corrosion.
