Hi,
Since a few months I got this problem that my indicators are not working when locking/unlocking the car (1.8 20v, 2003).
It happened while I was replacing the rear left turn signal light.
The 2 green leds for the indicators on the instrument cluster are also not blinking.
Things I already done:
- Checked every single fuse
- rechecked coding in VCDS if it somehow got changed
- replaced drivers front door lock (it was bad in the first place, that's why i replaced it)
- sprayed the hood latch (i've read that those things also can cause this problem?)
The indicators work normally, no hyperflashing etc, emergency lights also work normal when i press the button.
Did i miss something? Could it still be a bad relay in the hazard switch? Or is my indicator stalk dead? (Even though it still works for normal indicating)
