Most likely yh. Hows the clutch holding up?Are you having it mapped on 99 fuel if so i advise the low boost map which i had.
Yea all good no issues with clutchMost likely yh. Hows the clutch holding up?
Good to hear. The intake is on back order till january so will proberly get mine mapped in march/april when the weathers better. Was waiting for the black friday deal to come round and i guess i got excited. Been undecided on it for nearly 12 months and i finally gave in. Is there a selection of different stage 1 maps they offer. I thought it was just one?Yea all good no issues with clutch
Yh did see this but never paid much attention. I just would expect to run a remapped car on 99 as standard.Stage one 95
Stage one 99 low boost/ high boost
Stage one 97 low boost/ high boost
I think its like 16psiYh did see this but never paid much attention. I just would expect to run a remapped car on 99 as standard.
any ideas what yours boosts too on the low boost map?
Read the thread page 1How much are you pushing with the apr and supporting parts?
I see, what’s the differnce In low boost and high boost maps ? I’m a noob allow meRead the thread page 1
Cool thanks with a down pipe how much extra bhp you think I’d get looking to get it decatted then mapped togetherAPR 1.8 TSI/TFSI Gen3 ECU Upgrade for the MQB Platform
APR’s ECU upgrades are one of the best value modifications for the new 1.8T engine. The APR Stage I ECU Upgrade is designed to work without requiring other changes to the vehicle’s hardware. With the ECU Upgrade alone, APR’s Calibration Experts measured higher peak figures of 298 ft-lbs of...www.goapr.co.uk
assuming you have a 1.8tsi dsg all your info is on the link. i doubt the dsg will take the high boost map as the torque would exced the maximum rating of that gearbox. i believe the torque has to be limited in first and second. mines a manual so not to sure.
You better price for a clutch dual mass flywheel and crank thrust bearing then as this engine and gearbox is not made for stage 2 power.Cool thanks with a down pipe how much extra bhp you think I’d get looking to get it decatted then mapped together
No I’d keep it stage 1 with the downpipe don’t think the dsg can handle stage 2 power without some sort of problemsYou better price for a clutch dual mass flywheel and crank thrust bearing then as this engine and gearbox is not made for stage 2 power.
No supporting mods.So awesome rang today and it looks like im booking in for wednesday next week. Comes with 2 runs on the dyno aswell so will post the read outs and first impressions.
adam. Did u have any supporting mods when you had yours done? My induction kit wont be installed but i may just throw a pipercross panel in there for now till the apr one comes. Looking to get similar figures to what you got.
Yh the air filter is for noises mostly. Will have to catch back up after to see how you disable torque limitation ect. I guess i will need obeleven?No supporting mods.
Car did have a resonator delete makes the exhaust a bit more free flowing and sound better but wont add any power. Car is bone stock.
Stage 1 doesn't require any mods.
Its two runs my friend as it is tested stock to ensure it performs as manufacturer states. Then another run to test final output power after remap.
I hope you know that the air filter will add little to no performance gain. The stock is fine up to 300bhp.
Look forward to your results boss.
Enjoy.
Little tip i disabled engine torque limitation in ecu and also enable esc fully disabled option in ecu so that you can almost fully disable traction control so doesnt cut power at the slightest bit of wheelspin.
