I've found a few howto guides on the leaky door seals below, but they are from years ago with no pictures to go with them. Is there a more up to date one with pictures anywhere?
Thanks.
Water leak into footwell - dodgy seal info and DIY repair guide (Image links dead)
Ok, done all our doors now so thought I'd check the pollen filter whilst I was at it. The plastic cover fitted about as well as a thing that doesnt fit very well and the two plastic screws snapped when I tried to take them out! Undetered I pulled the cover of and what a heath robinson piece...
www.seatcupra.net
If it is wet just in the passengers footwell then the leak could be due to a poorly fitted pollen filter or cover. Pollen filter cover – to remove : unscrew and pull out plastic clips with screw heads (circled red) then pull up rubber seal from end, marked with yellow arrow. Pull...
www.seatcupra.net
Thanks.
