Foot rest upgrade
Sep 11, 2021
Hi there guys I am new to the forum. Have really gained a lot of info from you all already so I appreciate it.
I have a 2016 Seat Leon Fr Dsg. I have purchased some upgrade aluminium pedal covers as mentioned in many threads. However I am trying to identify the correct foot rest to fit my car. I have found a few on ebay for a golf mk7 but the sellers are not able to tell me if it will fit my car. Here is an example:
Any advice if this will fit would be massively appreciated! Thank you!
TripleBob
311
201
Trust me, they don't fit a DSG - they're too small! The footrest on the DSG is obviously much larger as there's no clutch pedal - you need a rhd DSG specific one - they're much wider and look like this;
Carl Levoir
74
24
Trust me a RHD drive version of the wider rest pedal doesn't exist, that's why someone come up with the one that the OP mentions.
I looked high and low all over the internet and couldn't find the RHD wide rest:)
Jay5959
FR 184
Apr 26, 2020
499
256
@Curtis611 what does your foot rest look like? Is it shaped like mine, the original I taken out was shaped like the one I’ve posted. Or is it like the pic that @TripleBob posted? Take a pic of your footwell. The link you posted shows it fitted with dsg pedals
TripleBob
311
201
Closest match you can get for RHD DSG that's the same width as the stock footrest are either the super pricey ones from OSIR design (who won't ship to the UK any more because Brexit), or these from AliExpress
The manual RHD ones can be forced to fit, but are too narrow
black_sheep
1,255
586
I have one of the Mk7 Golf ones from eBay fitted to my FL DSG Cupra. Not as wide as the OEM ones and up close the finish is not quite OEM standard; but nestled down in the footwell it looks ok next to the pedals. Fit is fine too - the OEM plastic one has a deep recess for the bolt so you can use the same bolt with the narrower aftermarket one.
2 photos. On the close up, you can see the indentation on the carpet where the original fitted (approx 15 mm narrower):
Reactions: Jay5959
black_sheep
1,255
586
I had a look on ebay but yours seems to be advertised as one for an automatic? I need one like yours (mines a manual too)
This one advertised is narrower than OEM plastic auto version, so is universal for manual or auto gearbox.
That is what is being referred to in post #4 @TripleBob above when he states that the auto one is too small.
bigbadjay
1,670
26
North Manchester
Gents, would it be better to find a plate type footrest that uses self tapping screws to fix? This way you could keep the wider footrest (much preferred for dsg tbh) I’ll be on the lookout for what could be compatible. Sure there was one for the MK2
Jay5959
FR 184
Apr 26, 2020
499
256
I seen someone post about this website a while back, they offer the footrests in manual or dsg. They don’t have the oem look similar to the pedals and they are bloody expensive, but it’s another option.
Reactions: bigbadjay
