Tara
712
326
Bournemouth
Just wanted to ask if anyone has swapped out there oem struts for these ? I've often thought that the original dampers can seem a bit crashy sometimes and thought in the past it could be improved and after reading some reviews they sound pretty good , I had a BMW a few years back and even though it was firm it seemed to soak up the bumps better and less crashy, now i know this is not a bmw but I think if you could find a more sophisticated shock it would be perfect.
I did. On stock springs. It’s really good esp the bumps. Ride is much firmer even in comfort mode
Is it uncomfortable firm ie crashy or does it soak it up better..... where abouts are you located ?
Not crashy unless u set to Cupra mode. Sports mode still
I’m Not from the UK, I’m located in Singapore where there are many humps.
