Following on from my thread here regarding changing my rocker cover gasket after finding oil on top of one of my spark plugs.
I ran into a few further issues of misfiring on Friday (first since changing), enough that i could hardly drive the car. I popped some new spark plugs in as they were looking pretty rough and it started up and drove without issues.
I now can’t tell if i have a rough idle or not or if it’s how it should be and i’m over thinking. It’s not fully smooth but it also does not jump erratically at any point (i’ll try and get a graph reading if i can)
After some searching i found a few posts regarding the PCV valve although these describe fluctuating revs when idle.
On a running cold engine i went to remove the oil filler cap, there was quite a lot of suction which i’m not sure indicates a faulty valve or not?
It could be fine but after all the work i’ve done to get things right again i wouldn’t mind making sure this is fine too! The car does eat through oil more than i expect. I’ll replace OEM if it needs it rather than any type of delete.
Leon Cupra 2008 1P
Cheers.
Leon Cupra 2008 1P
Cheers.
