Cupra Ateca VZ3 Boot
May 5, 2021
15
Hi,
Question regarding the VZ3 boot, apologies if this has been asked before.
I know you can order the spare wheel for +£100 on the VZ1/2 models of the car, but the VZ3 it is not listed as an option.
Does anyone know why this is? I've read elsewhere that it might be the sounds system and spare wheel that is already included..
Jam986
8
9
I have a VZ3 that was built in March. I can confirm that the boot has nothing in it (Sound system or spare wheel). They don't let you specify a spare wheel as it won't fit over the Brembo brake callipers on the front. If you really want a spare wheel you could still use it for the rear axel. Also, you could swap a rear to the front if needed.
Reactions: Brooster89
bgb
600
316
My model is a VZ1 and there isn't any space for the spare, lift the carpet and its flat.
Maybe same on VZ3?
ateca-chris
24
15
Maybe same on VZ3?
If you get the spare it comes with polystyrene fillers around the sides that hold the wheel brace, jack etc and lifts the whole floor up so it comes just about level with the rear seats when they are dropped.
pinky1959
62
37
The polystyrene fillers are extras if ordered after the car is delivered but the brochure doesn't explain this .
If being built from factory they are included.
ateca-chris
24
15
The spare on it's own might be around £100, but the whole kit including everything you need to hold it in place was around £360 i think.
I managed to get the dealer to go halves with me when I bought mine but it was a used car.
