Did you get yours sorted in the end?Hello,
Sorry to bring alive this topic again, but I have an issue with the blue connector ...
I received everything, but on my car, there is aleardy something connecting to the blue connector (see in attachment)
Can I connect the 2 camera cable somewhere else on this blue connector ? Or have I to disconnect the 2 cable already present and replace them by the new one ?
Thanks !
Not yet, I'm chating with @Bruno Maia , I don't what these cables correspond to yet. I looked a lot on the internet for diagrams, but without much successDid you get yours sorted in the end?
Can I know how many pin do you have on your blue connector behind de MMI ? Car you send my a picture of it please ? I don't know what to do with my 2 additionnal wires x)Ok so fitted the cam today, followed this guide but it wouldn't work on my brand new 2021. The pins are the same in the MMI and the coding but you have to do this command which tells the system you have a 'dumb' camera and not a high one.
ENG248437-ENG248800-function_configuration_rvc-rear_view_low_rvc not_active -to- Active
After this it worked.
I still have one issue though, I turned on the park pilot graphics which worked before the cam but now when its engaged they don't overlay like they do on the OE system. Is there a setting to get this to work again?
Installed alliexpress camera. Activated via obd11.. Now every time i change gear this message pops up..Have you activated Park pilot?
Hello brothers,Installed alliexpress camera. Activated via obd11.. Now every time i change gear this message pops up..
Hi I know this is an old thread but I have this very same issue, can you remember what you had to change for screen type?Right all fixed, I had to change a setting about the screen type and all the overlays came up. Not bad for a 20 pound cam. I didn't enjoy ripping all the interior panels off but it went back together ok. Thanks again for this info!
