Hello!
I’m looking for advice or to see if anybody else has had a similar problem or any ideas.
Car is a Leon MK2 FR+ 2010 facelift with 2.0 TSI engine, code CCZB. (211).
Fuse number 4 keeps blowing, it is the box in the end of the dash on drivers side. In the circuit is reverse light switch(so no auto sensor activation), interior mirror so no anti dazzle, oil level/ thermal sensor so warning light is on in dash, TCS and TPMS buttons, I also believe it to be connected to heating but not sure which element.
I have tried unplugging all of the components at different times and regardless the fuse just keeps blowing, causing me to believe it is a short circuit to ground causing the fuse to keep blowing. Sometimes it can last a 10-15 minute journey and be fine and then as soon as I turn ignition back on again it blows. Other times it blows before I even turn the engine on. The oil level sensor has been changed, and I have checked all engine bay wiring going to each component and all is okay and intact, can’t find any breaks in the wiring anywhere or any short circuits. All ground connections look and feel intact and good condition. Battery not too old, good condition. Radiator fan is constantly running as soon as you turn the engine on from cold, presumably a fail safe from the oil thermal sensor?
please let me know if anyone has any ideas!
