Don't worry mate I'm a cupra newbie tooYeah got it, thanks for the advice I've now got the burbles etc. and I can also hear the flap opening in the different modes. Me being a Cupra newbie
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Should have footwell lights on both sides, but they are not very bright as I have found out.Would have been nice to have a proper ambient lighting strip in the footwell where the pedals are and same position in passenger side. Realised it's only really lit from the ambient lighting in door cards
Are they just plain white too?Should have footwell lights on both sides, but they are not very bright as I have found out.
Yes like the one in the boot, I don't know if they are LED but I imagine they are?Are they just plain white too?
Ah right yeah I've noticed that tiny bit of lighting by your feet not great at all though and shame it can't be properly litYes like the one in the boot, I don't know if they are LED but I imagine they are?
Have you adjusted the brightness of the interior lighting? Look up interior lighting in the manual, p118, automatic will depend on driving mode, but I've set mine manually to be as bright as possible and it's comparable to my AudiAh right yeah I've noticed that tiny bit of lighting by your feet not great at all though and shame it can't be properly lit
Yeah did that as soon as got the car to brightest. I will have a proper look at night time as most of my driving has been done in the light.Have you adjusted the brightness of the interior lighting? Look up interior lighting in the manual, p118, automatic will depend on driving mode, but I've set mine manually to be as bright as possible and it's comparable to my Audi
You can set a speed limiter which gives you an audible and I imagine visual warning if you exceed a chosen speed. Don't think you can programme the traffic assist to a speed thoughIs it possible to force the trafic assist to run a little faster than the road sign ?
So if the sign says 50 you can set it to 55?
Is ‘Traffic Assist’ different to ‘Travel Assist’? because the latter can be set to any speed - it’s just ACC with added lane guidance.
Isn't the whole idea of automatic monitoring of speed to keep to the signposted limit? If you want a bit higher speed, then switch off that function in ACC and just set it manually.
No. Car will slow down for traffic but it won't slow down if the legal speed is changed.Then I loose the following trafic part of the assist ?
