Would you recommend an ESP DOT 4 to work better with stability control? Or is this more a generic marketing term?Go for a DOT4, they will mix fine with the brake fluid that is in there (should already be DOT4) and yes it is a case of just topping it up.
Brake & Clutch Fluid | Opie Oils
The UK's largest independent supplier of automotive oils, fluid and parts. We've products to suit any vehicle, from full blown Race / Track weapons, to Daily Drivers looking to save money. Plus FREE expert advice & recommendations - OPIE KNOW OILSwww.opieoils.co.uk
Cheers,
Guy
I think that you will find that the current VW Group fluid spec is effectively "DOT 4+" ie DOT4 but an evolution of the original DOT4 to make it suitable for ESP ect.Would you recommend an ESP DOT 4 to work better with stability control? Or is this more a generic marketing term?
There is some marketing to it.Would you recommend an ESP DOT 4 to work better with stability control? Or is this more a generic marketing term?
Excellent, thank you.There is some marketing to it.
ESP works using the ABS (and traction control) and for most ESP/ABS systems out there regular DOT4 or DOT5.1 is perfect, it is what the system is designed to run on.
So why do we have DOT4 ESP? There is no DOT classification for the lowever viscosity DOT4+, DOT4 ESP and the DOT5.1 ESP so a car manufactuer cannot really make a system that requires these lowever viscosity fluids and nothing else, when they are not classed by the DOT and technically do not exist to them. ISO have given them a class rating of 6, over the class rating of 4 for normal DOT4 etc. The main reason for them is for extremely cold climates, where the lower viscosity will perform better especially from a cold start. So unless you are in a very, very cold climate there is no advantage to using one over a regular DOT4 or DOT5.1.
When I look at the current data for random VAG cars they are all recommending regular DOT4, ISO Class 4 even up to 2020 models as standard.
Cheers,
Guy
Cheers,
Guy
I'm in the same situation as the OP, my brake fluid is getting really low and looking to get some fluid from Halfords tomorrow to top it up as ordering online, I won't get it till next week and was wondering out of these 8 brake fluid from Halfords, is the Comma DOT 4 ESP Brake Fluid 1L the best one to get?I think that you will find that the current VW Group fluid spec is effectively "DOT 4+" ie DOT4 but an evolution of the original DOT4 to make it suitable for ESP ect.
Some brands sell both, currently I seem to have bought in TRW ESP fluid.
Yup fine.I'm in the same situation as the OP, my brake fluid is getting really low and looking to get some fluid from Halfords tomorrow to top it up as ordering online, I won't get it till next week and was wondering out of these 8 brake fluid from Halfords, is the Comma DOT 4 ESP Brake Fluid 1L the best one to get?
https://www.halfords.com/motoring/engine-oils-and-fluids/brake-clutch-fluid/?prefn1=type&prefv1=Brake Fluid
