Is this behind the foam behind the carpet? I pulled back the carpet and I have a layer of thickish foam behind it. I didn't want to start tearing this out just in case. I'll try find this grommet as couldn't find anything earlier.Ok I have no pics
but if you peel back the carpet from where the clutch pedal would be (or is if you have a manual), you’ll see a round edge black rubber grommet - about 2 inches in size. It literally pulls out and provides a route directly into the engine.
Yeah it should be behind thatIs this behind the foam behind the carpet? I pulled back the carpet and I have a layer of thickish foam behind it. I didn't want to start tearing this out just in case. I'll try find this grommet as couldn't find anything earlier.
I've only found videos where the ODB is already fitted and they just point out it's location or its demonstrated but on a LHD car. I've been unsuccessful in finding a video that shows the grommet and where it enters the engine bay etc.There are a few installation videos on Cupras, Golf Rs, S3s online which show the different fitments on either side of the engine - there was an S3 owner that had created a bracket that fitted to the air box mounts (after fitment of non-OEM induction setup).
I've seen this video and I didn't find that video very useful as everything is already fitted with panels and grommets refitted etc. I may have crap eyes but I cannot see where that OBD cable goes in that video when he points the camera behind the turbo.
About 40 seconds in for engine bay through heat shield and then internals later.
