huge list of faults, bad earth?
ozaudio
387
north west
with there been so many faults at once, what do you think the chances of all these sensors going bad at the same time.
10 Faults Found:
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
16497 - Shareware Version. To Decode all DTCs
P0113 - 35-10 - Please Register/Activate - Intermittent
16486 - Shareware Version. To Decode all DTCs
P0102 - 35-10 - Please Register/Activate - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16706 - Shareware Version. To Decode all DTCs
P0322 - 35-10 - Please Register/Activate - Intermittent
16885 - Shareware Version. To Decode all DTCs
P0501 - 35-10 - Please Register/Activate - Intermittent
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-10 - - - Intermittent
17705 - Shareware Version. To Decode all DTCs
P1297 - 35-10 - Please Register/Activate - Intermittent
17608 - Shareware Version. To Decode all DTCs
P1200 - 35-10 - Please Register/Activate - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
Readiness: 0000 0000
mty12345
4,040
644
bristol
Like you say, i'd definitely suspect a earth, or if not then a main supply relay with that big list.
Rich-I-Am
132
Bedford
Hows the battery? Being as the faults are intermittent id say the chances are its one common fault. Have you tried clearing the faults, driving it and then plugging in again?
ozaudio
387
north west
yep they all still come back, today I installed a new ( or nearly new ) speedo senser, and my speedo guage still isn't working
batt had a very good float voltage of around 12.9v
been to a local VW expert and he said the fact so many sensors are playing up at once would suggest wiring, he said go for the cheapest option of a new loom from ebay first
does anybody know if the cupra and cupra r shar the same engine loom? I can get a loom from a cupra from 2 locations local to me.
ozaudio
387
north west
there is some were, but I should imagen itll be an under bonnet earth, not checked but is there any located near the ecu? the 2 under the bat tray have been brushed up with a wire wheel on the drill and then linked together with 8 guage cable , tested the voltage and its exactly the same now as it shows when been tested directly across the bat terminals
ozaudio
387
north west
thanks a lot, which is the main supply relay if you know? ill grab one from a audi 1.8t if they are the same from the scrappy, starting with all the cheap options, tomorrow will be a loom from ebay if no joy today,
ozaudio
387
north west
looking at the loom in the engine bay, even though the lambda sensor is included in the list of faults, that cable doesn't run downt he same loom as the rest of the sensors. it joins up right at the top of the engine on the same loom as the lights ect.
tomorrow I will check to see if my ecu is wet and see if any of the connections are rusty awell. ill also test the speedo cable from the ecu to the speedo sensor to see if there is any breaks, also check is there is any short from ground to live.
any body have a ecu pin layout at all? cheers
p.s - if you have a cluster layout aswell that's great aswell :)
ozaudio
387
north west
so I checked the ecu and as I pulled the engine loom out 2 pins from the ecu plug came away with the engine loom plug. I removed the ecu and took it inside and hit it with a hair dryer, I pulled the 2 pins out slightly so that when the plug got pushed back into the ecu they touched. but still nothing!
ozaudio
387
north west
so I decided to take to some sensors with a meter, and im going to just pass this one over to an auto electrican lol
green / yellow on the MAF is a live, but if I test it against the live from the batt I get a reading of 12.x volt!
when the cars started I get a reading between the same cable of around 0.x volt
i also tested the earth against the fuses inside the car and a couple of them had 0 power weather the car was running or not
EDIT
after more testing of unplugging sensors I now seem to have less fault codes, I haven't done anything to any wiring but I seem to of removed some faults some how?
2 I can ignore, 1 is because the n249 is unplugged / bypassed and the second is the battery has been removed from the car
17695
17956
P1200 - 35-10 - Please Register/Activate - Intermittent n249 bypass
Battoussai
499
160
Portugal
Hi mate, it's built into the hazard warning light switch. You will have to replace the complete unit if faulty. Think there are different part numbers depending if you have a towbar or not. Probably best to get the exact part number off of the old one.
https://www.ebay.co.uk/itm/SEAT-LEO...890567&hash=item216d404b67:g:sjkAAOSw9D1ef9Zp
Hi there.
I changed my MK1 diesel hazard light button (relay built-in) a couple years ago. I still have the OEM box and faulty one and the number is 1M0941509(B). Mind this is a European version.
Maria
my mid-life crisis car
Jun 22, 2016
143
20
South-West
Ah so glad I didn't start taking the poor car apart in the rain this morning to get behind the fuse box! Thank you Mty saved me a lot of work there.
Reactions: mty12345
