Plus (Mib2 High) was / is an option on the Ateca and Ateca Cupra specific where its the only option. Mapcare is not currently supported in the UK although retrofit software follows the same controls. Whether non UK based or retrofit, reviewing the Mapcare FEC tells you whether you have the ability to updates the maps and when it runs out.
How to do it:
1. Hold Menu button until service mode shows.
2. Press "Function enabling codes (FEC, SWaP)"
3. Press "Installed codes"
Look for the FEC starting with 073 and note down the two last characters as per image example.
Use the table:
Code Allowed - Map Update month
For example if the Mapcare code ends in 22 you can load up to and including the June 2019 release but can't go beyond. 16 covers June 2016 but not beyond. 10 doesn't include 2015 June. 3f means you can update to November 2026 etc.
Those people with Mapcare or retrofits can check up to when they can update their maps against the serial release.
Derivation is here, post 1914:
https://forums.seatcupra.net/index.php?threads/navigation-system-updates.388586/page-96#post-4894481
Interested to see the Mapcare FEC of Skoda and VWs which are said to have unlimited updates. Last two characters. May be it's done a different way when Mapcare is scrapped with a different code which means don't bother to check for Mapcare. Welcome people posting these up on recent Discover Pro and Columbus units where you have access to these vehicles to aid understanding.
BTW these Mapcare limiting function update codes apply to all Seat Plus units, have different lead in codes for other VAG brands but similar / same last two character sequences.
Edit. 14.08.2020
a new Mapcare FeC now appears to be offered by Seat in Europe. That's the one to have if you can. The table above is also validated from post 49 in an exchange of FeCs and Seat material. EE is the end point of the Hex table and takes you to the year 2074. How common this FeC is installed in Europe is currently unknown and on what basis. For example whether the 120 Euro option of Mapcare is now extended to life rather than three years. The FeC code was said to have been introduced in 2019 models.
Edit. 19.06.2021
Unhappy with your Seat navigation FeCs ?
Solution here... Follow the links:
How to do it:
Use the table:
10 | |
11 | 2015 June |
12 | |
13 | 2015 Nov |
14 | |
15 | 2016 June |
16 | |
17 | 2016 Nov |
18 | |
19 | 2017 June |
1a | |
1b | 2017 Nov |
1c | |
1d | 2018 June |
1e | |
1f | 2018 Nov |
20 | |
21 | 2019 June |
22 | |
23 | 2019 Nov |
24 | |
25 | 2020 June |
26 | |
27 | 2020 Nov |
28 | |
29 | 2021 June |
2a | |
2b | 2021 Nov |
2c | |
2d | 2022 June |
2e | |
2f | 2022 Nov |
30 | |
31 | 2023 June |
32 | |
33 | 2023 Nov |
34 | |
35 | 2024 June |
36 | |
37 | 2024 Nov |
38 | |
39 | 2025 June |
3a | |
3b | 2025 Nov |
3c | |
3d | 2026 June |
3e | |
3f | 2026 Nov |
40 | |
41 | 2027 June |
42 | |
43 | 2027 Nov |
44 | |
45 | 2028 June |
46 | |
47 | 2028 Nov |
48 | |
49 | 2029 June |
4A | |
4B | 2029 Nov |
4C | |
4D | 2030 June |
4E | |
4F | 2030 Nov |
50 | |
51 | 2031 June |
52 | |
53 | 2031 Nov |
54 | |
55 | 2032 June |
56 | |
57 | 2032 Nov |
58 | |
59 | 2033 June |
5A | |
5B | 2033 Nov |
5C | |
5D | 2034 June |
5E | |
5F | 2034 Nov |
Edit. 14.08.2020
POIs beim MJ19 Navi
Hier mal mein erhaltener Emailtext von Seat Deutschland zum Import von POI´s
www.seat-leon.de
073000EE | DB_EU_MIB2_HIGH_SEAT_Lifetime_Mapcare |
Edit. 19.06.2021
Ordered a 32GB Skoda SD Card from Lithuania, took a good 10 days to arrive but it is the real thing. V14 1730 with part no 5L0 051 236 CH Europe 1 (All Europe in SEAT speak). Ported over my OVERALL.NDS file and it worked straight away. I have also upgraded my old SEAT V7 Card to V14 with GB...
www.seatcupra.net
