Thanks @Yellow fr ... brake is now sorted although it did think that i had a duff caliper as I went out and came back to a very hot brake! Turns out the inner bad hadnt seated properly... could have been an expensive mistake, but all sorted now.
I respec' the fact you cleaned the bolts.
I'm slightly annoyed that they are scratched, I think someone has tried to clean them before with a screwdriver..... I may replace them
It beggars belief. There’s not many garages i trust these days, found a really good one though so if I get stuck then I know they have my back. They have also said I can hire a ramp if I need to.
I was reluctant to use a wire brush on them in case I got micro scratches in the clear coat. Luckily it was a non issue as they'd gone through the clear coat and taken the paint off.. and some of the top layer of metal from the looks of it. On the bright side, least I don't have to look at it once everything back together. But it's why I prefer to do as much as I can myself these days.
There’s a part of me that’s tempted to take the axle off and get it blasted and powder coated whiles it’s apart...
You won’t be happy till it’s done.
If it’s not too much extra work to do it now, wouldn’t it be best to get it done, that’s if everything is available to get it done.
You know me! It’s only a matter of a few more bolts, there’s a powder coater not far from me that’s still open, he works alone so I imagine it’s easy for him to socially distance.
I’m going to strip the other side down tomorrow and then decide what to do... and by decide I mean take the axle off
If you have a angle grinder with a cutting disc you can use that to cut into the head off the bolt so you can use a flat blade screw driver to unscrew it out if not you could try a hammering a Allan key into the rounded bolt or a muti spline into it if your not getting straight onto it you can take the wheel bearing off so it’s easier to get on to the bolt and the back plate can be removed
