Cam chain-timing chain?
Oct 10, 2019
38
Greetings, is the so called cam chain+ tensioner simply a timing chain kit or? I ordered one and not sure is that it. I got the chain and the tensioner. Whenever I type cam chain kit it gives me timing chain results instead.
Oct 10, 2019
38
I received item under part number 06d109229b, is that correct kit for cam chain tensioner and chain? My engine is ea113,cam is run by chain while water pump and timing is ran by timing belt. I received both "timing belt kit" and "timing chain kit",not sure do they mean by "timing chain kit" on cam chain kit
Brimfull
1,385
418
Wrexham
That part number is for the timing chain and tensioner, also called cam chain and tensioner kit
