That’s that theory out the window thenI have run my car since 0 miles on premium unleaded (now on 12.5k) and have the issue. Never put any 95 ron in it
Happy to trawl through part numbers if someone has access to the schematics for the engines...So, what someone needs to do is to first establish ALL the differences in part numbers between the early versions and the latest one - that would take a few minutes/hours, and try to work from that what the issues/implications were/are?
I read on another forum skoda attributed the kangarooing symptoms to lack of torque to the alternator on cars with build dates July / August 2018 and a software patch was all that was required to fix (apparently)Two things that I did not know, the lower powered engines are listed as Miller Cycle, I thought both the low and high output engines would be the same, seems not. Also the lower output engine gets variable geometry turbo! I can't see that the comments about the higher output engine's turbo will mean much - maybe just the difference that existed between how the excess pressure is handled a bit like the difference between the early 1.2TSI 8V and the later 1.2TSI 16V turbos.
I'd think that there will have been changes to the internals of these engines, remember, mainly, it was only the higher output engines that got most complaints on these forums, and accordingly, the engine ECU S/W updated appeared quicker for them, and lots of people considered that it was the Miller Cycle characteristics that were leading to the rough low revs behaviour - but if it is only the low output engines that get the Miller Cycle tag, then maybe that theory goes out the window - which is probably a bit more encouraging for those with the Millar Cycle type of engines.
Gives us something to do in our spare time I guess, playing detectiveI certainly enjoy reading all the theories on why these engines kangaroo. Although for my 1.5 what has bewildered me is why after the update and subsequent 200+ miles, it was kangaroo free, and then re-emerged? And why for some, the latest software update has worked fully and is holding, and for other it has not / or partially did.
It just seems so doubtful that VW thinks it can be fixed with just a simple software update, with so many other variables at play.
There really is no end in sight.
Be interesting (but probably unlikely) to get the engine, crankshaft, etc. numbers from affected cars...affected cars that have seemingly been fixed...cars that software hasn’t made a difference, etc. to see if the cams/other internals may be affecting results.Hang on, hang on.....
Just come across this as well. The only other info teased out here is the type of turbo charger on each model of engine.
My purchased hour has just run out and I'd rather spend money on another car than throwing it into SEAT's coffer.
I started to look at the engine cycles but my understanding is the intake valves close early on both cycles rather than late and so would eliminate blow-by back into the intake manifold stalling the turbo that way and causing the pressure to fluctuate.
Is the gpf before or after the hot side of the turbo?
I may be way off the mark here if VW gurus can’t solve it but I enjoy thinking about this kinda stuff.
Thanks pompeydave...cars are the one thing in my life (outside family) that I’ve always been fond of...good or bad I love them and I love a challenge trying to work things out and fix bits myself (where I can) whether to help myself and/or others. I don’t have the time I used to when I was younger (and before kids haha) but if I get a bit of spare time this is what I enjoyIt's guys like you Geoff that make this forum....going that extra step...Topman.
I've been looking at the 1.0 / 1.5 as a possible replacement for my 1.6t Astra . I don't need 200hp anymore poodling around town but I also don't have any kangarooing in my Astra. I may have a look at the Ibiza 1.0 115 Fr but still like the slightly bigger Leon , if only they sort the issue out.
Back in the summer when I had the car in for diagnostics (Dealer refused to acknowledge there was a kangaroo problem for many many months) they did say the 'fuel injector rail pressure switch' needed checking, but no swap was required. So I wonder which variants of the engine did require this swap. I couldn't find a TPI for it on erwin.
Sound like a fairly strong candidate...I’ve run mine in eco tonight and it was slightly better again...occasional hiccup...I’ve noticed something odd with the revs now where sometimes the throttle pedal doesn’t always seem to quite equate to the same input...maybe that’s just me but I will monitor that for a few days as it’s something I thought I noticed last week but then put down to me getting used to a new car and playing with the setting so I’ll leave it in eco for a bit and see how we go.Back in the summer when I had the car in for diagnostics (Dealer refused to acknowledge there was a kangaroo problem for many many months) they did say the 'fuel injector rail pressure switch' needed checking, but no swap was required. So I wonder which variants of the engine did require this swap. I couldn't find a TPI for it on erwin.
Can’t beat going one step forward and two back haha.When i got mine when it was new 68 plate (first of the 1.5 tsi’s) i didn’t even know the 1.5 tsi existed, it was that new in the leon the dealer only had a 1.4 tsi 125 demo, so sold me the, oh yes sir the engine will be just like this one, only better, 130 instead of 125 and much better on fuel.
so i didn’t even drive a kangaroo 1.5tsi until i collected my own leon
