Breather pipe kit for LCR Mk1?
mph
111
Liverpool
I recently decided to take my 14 yr old LCR to get a dyno measurement done, since I've never known what it was pulling since my remap about 10 years ago. The guy suggested I should first change all the breather pipework as some bits were starting to look a bit worn. He said I could probably get a kit rather than buying individual pipes from the Stealer.
Does anyone know of such a kit and where I can get from? Or recommend any particular brands or materials to use? The engine is running fine and after a steam clean there doesn't appear to be any leaks, but he said it's just a precaution.
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,216
732
Leeds
You can make your own and throw a catch can in for good measure (helps your octane rating)Just need some 17mm pipes and a t-piece plus catch can. I got all the bits for 60 quid
bigT's lcr
Feb 27, 2016
1,216
732
Leeds
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/p/940443615
This is the catch can i bought.
Then get 1m length of 17mm silicone pipe off of ebay (auto silicone hoses 'ASH' are good)
1x 17mm t-piece from ebay
Piece of pipe from Servo to bottom of tpiece
Then left is your pcv right goes to the catch can and then to TIP
plus you'll need 7 or 8 jubilee clips
