	Looking good man, hope to see it at one of the meets next year.Engine finally in position today, more cleaning and painting behind the scenes.
Rocker cover gasket replaced, dog **** cam chain tensioner tool cracked after several attempts and tweaks with a file to make it fit properly.
AC pump, alternator and PAS removed and cleaned.
Spare AUX bracket fitted, oil filter housing removed and I've painted a spare which is drying as I type.
New injector cups installed into freshly painted inlet manifold which was then bolted onto the engine only to be taken back off 10 mins later as the brake cleaner I used to clean the new cups had eaten into my new paintwork FFS!
I guess I'll be painting that again in the week and can only assume it hasn't cured properly due to not having any heat cycles yet, time to dig out the heat gun!
Here's how it currently sits anyway.
?Please cease and desist with immediate effect !!
