CupraNJ
110
40
Bristol
Fitter the de rigueur, or should I say de Rieger, styling mod to the ST. Well made and easy to fit. Very pleased with the finished article.
CupraNJ
110
40
Bristol
How did you get the front from the ground?How did you fit it?Looks great!
Verstuurd vanaf mijn LYA-L29 met Tapatalk
Thanks.To lift front end I used a trolley jack and axel stands. The splitter is supplied with a fitting kit which consists of self-tapping screws and spire/U clips. Four existing screws plus additional holes drilled in the underside of the front bumper and the remaining screws and clips are usedt secure it. The front wheels need to removed to access the backside of the bumper to fit the clips for some of the screws.
I did it single handed, but would be easier with a second person. It's aligned with the four pre-existing screws. Some people also use an adhesive, it is solid without it.
I've got some side skirts to get fitted next.
Reactions: donoli74
ryzzey
165
42
Dorset, UK
Well me and my MK3 Leon didn’t do anything exciting today but I did arrive home to THREE letters from France, each one a speeding fine from my trip two weeks ago. One for €90 and the other two for €45.
There was me thinking speed cameras in France cant catch an English car, how wrong I was! I remember being flashed by quite a few speed cameras too (actually more than three!)
Things must have changed recently as I drove through France on four occasions last year triggering quite a few cameras and never had any fines come through. Be careful out there guys!
Dr.Dash
342
73
Midlands
Full service.
Bought all the parts and fluids and got my local reliable tech to do it all. (Oil, oil filter, air filter, pollen filter, brake fluid, coolant).
2nd MOT.
Passed no advisories. My car also seems to be zero emissions according to the printout, perhaps I can avoid the Congestion Charge?!
Bit of a clean. Made sure all the drain points are clear, they seem to block easily, but a wipe down and poke with a blunt stick does the trick. Even the filler recess drain clogs up despite being largely enclosed.
Replacement. Thinking of replacing my Leon, but then I can't find anything I like more.
Still really enjoy driving it and the low running costs. Don't want a 5 door so that is an issue.
Theporter
141
57
Installed the stage 1 bluefin today omg what a different beast I thought it was quick but it’s like lightning now it’s like whizz for a car if I don’t post again I’ve died smiling lol
MrJohn91
136
64
www.facebook.com
Yay for the cold months where my right headlight is as sleepy as I am and stays pretty much on the floor and my rear wiper decides to stop where it feels like it... I forgot about those "winter features" for at least 8 months!
Has anyone actually paid to replace the regulator in the headlight know how much it cost?
Sent from my CLT-L09 using Tapatalk
hilly81
265
43
Little Sutton
Took it to SEAT to get a couple of things sorted under warranty. They have given me this awful Citroen, Cactus thing as a courtesy car. Sounds like a tractor and it's a petrol!
Reactions: ryzzey
Kirky
Copper Cupra Advocate
Apr 10, 2019
1,042
497
Is this for the WLTP Cupra ir older model?
Hag
399
193
3cyl petrol mmm nice
Gilding92
129
72
Easy to install?
Ermmmmm, not too bad.
had to reorder alloys as I messed up the centre caps first time round. But once you’ve put a few things down and got a feel for how the vinyl works then yeah it’s relatively easy to install. By the time I’d done two wheels I was flying.
