I know this is an old thread but I'm hoping to do this mod an I'm a little confused
There seem to be 2 types of folding mirrors. Tear drop and the rectangle type. Do both types require motors to be fitted to the door as well?
I don't recall any motor with a part number ending in 'G'. You sure it shouldn't be a 'C'?
Big thread revival!
I've retrofitted these mirrors to a 04 Leon.
Followed the part numbers as instructed on this thread.
Drivers side mirror folds no problem.
However passenger side mirror won't operate. I've tested it as working by transferring it over to driver's side, and it's fine.
Just won't work when plugged in on the passenger side.
The motor fitted is a 1J0959801G, thought it could be a faulty part so it was returned to seller and replaced but still the same problem.
One thing though, with the 1J0959801G motor fitted, the passenger door won't lock. Window winds down fine though.
Any ideas? Could it be possible that both motors are both faulty or is this unlikely?
At the moment only got 1 working driver's side folding mirror.
That's the part number given by Lee69 on page 3.
That part number matches with etka catalog http://www.oemepc.com/seat/part_sin...hg_ug/959/subcategory/959010/part_id/0/lang/e
Maybe the mirror is faulty. Is the plug identical on the drivers side? If so can you plug the passenger mirror into the drivers socket and test the mirror motor that way?
Already ahead of you, plug is identical. Plugged it into driver's side when I wasn't having any luck and it works perfectly.
Can't think what else it can be.
Can't be 2 faulty window motor units.
Ah right mate, no i'd think the likelyhood of having two faulty motors is highly unlikely. In that case i can only imagine the fault is in the wiring in the passenger door loom. The connector for it is at the bottom of the A-pilliar, so it could be worth getting a door loom of ebay and switching it over, can't really see it can be anything else.
Upto you, but by the time you run it down through both doors, across the dash, and then sort the wiring out (with no certainty that one window motor can provide enough current for 2 mirrors) then i'd just try swapping the door loom myself. They are easy enough to get hold of as these cars get broken all the time now.
Having a look through ETKA, older models were fitted with that part number. The date stamp on the parts seems t be circa 2000MY. Have a look at 1C0959801C. Possibly pre-facelift/facelift numbers
Thank you for that.
Yeah this one is a facelift model, 04/05 with teardrop mirror etc.
Are you able to do a check from the reg number?
