Thanks i will checkI use Tigerseal or Stikaflex for spoilers, etc - remains flexible but keeps things in place
Most bodyshops will recommend either of these - can be found on ebay
No bumper removal required.
Splitter has 22 pre drilled holes in it. Hold Splitter up to car and 4 will align with 4 self tappers already on the car (these go through overlapping panels so need to go back through them when you reinsert self tappers). Remove these 4 and hold splitter up and reinstate the 4. Splitter is fitted in position. Using a 3mm drill bit and the 18 pre drilled holes left, drill pilot holes. Then using supplied self tappers fit the last 18 and stand back and admire your work.
You can use silicon between Splitter and car to aid it staying in place and to keep water out.
Hi
My Rieger splitter arrived today ready for fitting this weekend. Did you use the 6 spring clips supplied and if so could you get behind the bumper to fit them with it on the car? Did you use silicone and if so did you use it all the way around the top?
Thanks![]()
I used about 4 as already said with the bumper on the car. Mind you I had the advantage of my nieces bf having a garage with a car ramp so was easy to get underneath.
I did use silicon and followed the full length of the splitter to help seal it from dirt and water trapping.
As property maintenance guy normal quality clear silicon was.more than enough strong.Thanks
Silicon as in tigerseal/ stikaflex or general household?
For blade i ordered teroson factory glue.
Seat not sell just the cover if missing complete blade need it £360Blades arrived missing small cover parts
Anyone can help with part number end of the blade cover?
Installed mine yesterday, only used self tapping screws to hold on... do we think it will last or should it tape it up as well?
Sent from my SM-G975F using Tapatalk
No pal I used the hex head self tapers which have the rubber washer pre installed on them like the ones in the pictureDid you use any of the spring washers behind? mine feels solid with fitting several of them
I installed mine in the same way - I could do pull-ups hanging from the splitter, so it is fair to say it would take some serious effort for it to come loose.
Mine has been in for over half an year and still feels just as tight (I checked yesterday).
Whats the difference in material between ABS plastic and fiberglass when it comes to these sort of pieces?
