In short, What’s the part number for the 280 2.0TSI coils? Do I change all 4 at once?
Story below
Right so had my vacuum pump changed today as it was leaking.
Unfortunately the car started misfiring after pulling out of a junction with moderate revs. I Called up the mechanic to see if it was related to the work done, and also got hold of a mate who is a mechanic. They came out and it’s not related to the work done, they even swapped back the faulty part to check and it’s still running bad.
They ran diagnostics and it’s coming up as a misfire. The EPC and check engine lights came on the dash. The car was over fuelling and blowing out smoke and fuel from the exhaust so they seem confident it’s the coil pack.
I’m not having much luck with my new motor. It’s done 30k miles and has a full service and MOT history. I guess these things come all at once to test us!
Is it worth changing all 4 at once? My dad tells me that it makes more sense as if one has gone there’s a decent chance another will soon.
Story below
