Does anyone have the Maxton sideskirts?
Deleted member 103408
these are pre facelift ones if you want close ups just let me know
Reactions: Jaco2k and stel94
Jaco2k
AWD FTW
Mar 11, 2018
1,044
641
Tampere, Finland
www.youtube.com
Thanks - about the fitting, do they only go in one way or can you kinda tweak how much they stick out?
Is it just a matter of using self-tapping screws of did you glue?
I would be interested in some photos from the underside, along with vertical from top to see how much they stick out - near wheels would do.
OK I will take some pics and load them up later.
Had them fitted by body shop along with the front splitter from what I can see its self tappers and glue which holds them in place fine.
Reactions: Jaco2k
Naylor92
273
52
I have fitted my front splitter and rear diffuser. Plan to do the same with the skirts ;)
I’ve just got mine this week. Waiting to fit them this weekend. I already have the maxton spoiler cap on and Rieger Front splitter.
Reactions: Jaco2k
Jaco2k
AWD FTW
Mar 11, 2018
1,044
641
Tampere, Finland
www.youtube.com
BTW, off-topic, but I did not glue my splitter - just used the provided self-tapping screws and to test the fit, I hanged myself from the splitter while under the car and it did not move the slightest bit.
Won't say it will never leave, but I am pretty sure the bumper would be torn first ;)
Thanks for the pics - that looks ok, I think.
Maybe I would like to have them stick out a tad less.
As you can see from the underside pics there is room to go in or out
And you will have to adapt mud flaps (i took mine off and never got round to making them fit) if you have them
Reactions: Jaco2k
I only know there is glue because he told me he did that, its not obvious so its only a small bit in my opinion.
Jaco2k
AWD FTW
Mar 11, 2018
1,044
641
Tampere, Finland
www.youtube.com
From what I understand from reading, if you want to be 100% sure it stays there, you have to glue it. The glue is a special glue and kinda melts the plastic like is it is soldered.
It for sure won't come out - if you just screw it or just glue it, the glued option is more sturdy.
