I’ve done track days before and know I like them. But until I have a second car again, it’s not worth the risk.Simple answer you both need to come to the Doncaster meet to decide if its for you and so we can all go oooh aahh
What do I need to decide is for me then? LolSorry @Damo H I know I spend a lot of time on the track this is just a SCN Car Meet.
^^^ what paddy saysNo, you get them in addition to an exhaust.
Don’t want to lower it too much. Which was why I wanted springs initially with the original setup. Not interested in tweaking the setup. Want to set it up and then done. So was going to get the 034 motorsport top mounts to increase the front camber and just adjust the rear with the current setup. The R ST coming out suggests 2 degrees on the rear is a good setup in the estate. My old mini had an awesome stance with the camber front and rear.Drive a car with it fitted (ooh I have it fitted and its been in for a while) but you need to get @kiddo to come along then you get the feel in an ST rather than the 5 door.
However my requirements when I bought this setup was I wanted to be able to lower the car but I did not want to ride on coilovers (eg very uncomfortable) and this kit does the job. The only downside I can see if you want to start doing lots of changes with geometry you will not be able to as this setup is just to give comfort and lower not allow your to carry on developing the setup.
Looks like the carbon mirror caps have been dropped
Wish this colour was available on all Cupra’s
Pretty sure @paddy6789 s will be too hard/bouncy based on reviews of Golf R owners. They recommend Emmanuel but they're lower still. I think Eibach are highly rated but don't lower enough for them so maybe right up my street. Only thing against the KW DCC setup is cost. Can't find a decent full system for the Carbon. Only one that seems viable is the Remus system but that's £2,500 and not £1,500 better than my last BCS system.We both agree on setup, thats why you need to see another car to judge if its ok for you vs Springs.
Mine will be to low for you but @kiddo sounds like he has it like you want ti but as we always see you need or if you are happy with the Springs then go for it.
How much did this cost you all in?I've had a set of KW ddc coilovers fitted. Initial impressions are excellent with the wallowey feeling from comfort mode when pushing now gone and less body roll. cupra mode is less harsh but more compliant. I went with 25mm drop and will see how it settles over coming days. It may be coincidence but I noticed less wheelspin in the wet. Normally I'd expect some wheelspin @ wot in 3rd when climbing towards the redline but on way home I couldn't get the wheelspin. Maybe the rain is grippier in Irlam lol
The drop you've done of 25mm, is that like the highest setting on the KW's? Their site says they drop 35mm minimum, so I'm assuming that is not the Cupra which has 10mm lower suspension anyway.Too much lol
