Leon Cupra 300 2019 brake calipers?
Snowman
306
24
I've tried to do some research to what kind of calipers are on the new 2019 300ps Cupra, without any real luck..
Are they regular 1piston calipers or the same kind of 4pot calipers that are to be found on the Audi TTS?
I've tried googling and also checking schematics, but there are no new ones to be found..
Does anyone here know for sure what calipers there are on the front?
Snowman
306
24
Awh i was hoping for it to be the slim 4pots from the TTS.. But i guess it would have been to good to be true.
Instead its an easy upgrade :)
Damo H
4,707
2,816
Car Length In Front
Normal ones have 1 pots, but if you can find a car with the performance pack they’ll have the 4 pots. Not sure if that pack is available on the new 2019 cars though. Been dropped in the UK some time ago.
Carbon Edition and Cupra R have them too.
Snowman
306
24
I can spec a car with it, however the TTS calipers are thinner and will work with stock 340mm discs.
So i will be able to use 17" wheels for winter and dont have to spend a fortune on rotors :)
Reactions: Damo H
Snowman
306
24
TTS and TTRS must have different callipers.
Yes The tts one seems to be 4pot but thinner then ttrs ones. Also you can get ttrs/rs3 calipers with different brackets to use with 340mm discs.
However the rs3 calipers are still very thick so it can interfere with some rims .
_Dejan_
144
66
Performance Pack have TTRS front brakes with 370mm discs and 4pot brembo calipers.
stig
31
18
Carbon edition has 4 pot Brembos which are Audi stamped! The bell and rotor are Audi too. I know this from thoroughly cleaning mine at the weekend - see pic :)
sumogtr
124
46
Watford
Anyone know whether the 4 pot Brembos and 370mm disc used on the previously available Sub8 pack in the UK will fit onto a 2019 Cupra 300 St 4 drive without having to change rims and other parts?
Blowski
Cupra 280 DSG
Mar 23, 2018
420
201
Pretty sure you'll have to change the rims. You couldn't get the Sub 8 with the standard wheels.
