Hi, yes it offers these and more..Can you alter the DRL to 100 percent brightness with the Carista app? And can other things be altered, like the alternate indicator blinkers. Or is VCDS or OBDeleven needed?
Cheers.
Cheers.
Would you say it’d be worth getting one then ?Just had a play about with Carista so thought i'd share my thoughts.
1. disabled start stop (you cant override it with the button so its off permanently)
2. Enabled alarm chirp (It works but the volume is very low can it be turned up?)
3. Needle sweep (didn't work on the new digital Dash)
4. Soundakor (I turned it off at first and its amazing how much fake noise comes off it, and i can now hear the exhaust crackles much better however the whole exhaust and engine note is very quiet so i turned it back on at 50% mine was at 96% default at 50% i think its still too loud so gonna turn it down further. If i get a res delete in the summer i will be turning it off completely.
I haven't tried the direct throttle change yet and i think ill leave the xds alone.
I only want it to change a few little things. Just not sure exactly whether it can be done with Carista.@Naylor92 You need to need to work out what you want from these tools and then see if they provide what you want
The communication dongle you need for Carista will also support lots of other apps (like Torque Pro etc) so its not dead money for the dongle.
Used mine for the first time today - Beta version. Both those options were available on Carista.Can you alter the DRL to 100 percent brightness with the Carista app? And can other things be altered, like the alternate indicator blinkers. Or is VCDS or OBDeleven needed?
Cheers.
I tried the direct throttle response, but personally I felt no difference.Just had a play about with Carista so thought i'd share my thoughts.
OBDeleven still not compatible with iPhone yet? Is there any other way you can use it other than having an adroid phone or tablet?
No I don’t have one. Just deciding on whether to get Carista or wait for the OBDeleven?
No haha!!OBD Eleven are currently working on IOS Version scheduled for end Q1 2019 (Eg Ready in April I suspect).
In the mean time simple answer is no unless you are good with Windows or Mac laptops as i have seen you can create VM Partitions and run it there but it does not look easy.
What’s that mate?Carista it is then. You can always use the dongle for other stuff like Torque Pro
