Deleted member 103408
I don't have this car but I seem to recall you have the Brembo brake kit so just make sure that 18" will fit over them.
I’d go with pro race in 18”. Stronger wheel and look nice plus cheaper tyres.Yes,they are there for a purpose.
Painted,NOT diamond cut.
Easy to clean design
Cheap...your best wheels for the other 8 months.
Anyway,I'm still undecided and may still go for the TD pro race which apparently fit in 18"
18” do fit, just, depending on the wheel and position of the wheel weights.I don't have this car but I seem to recall you have the Brembo brake kit so just make sure that 18" will fit over them.
Choice wise, 18” would be a better option and give you more options. The ride quality will be better. The TD Pro will always sell when you are finished with them.Yes,they are there for a purpose.
7 currently on autotrader...Looks like the Carbon’s are starting to be sold as the price becomes a little more realistic. Only seen the one locally to me yet but looking forward to seeing them on the road as they get bought.
Just to add to this I bought some wheels / tyres through these guys and am very happy with them but on checking the invoice I noticed they gave me a 35 offset (which because my car is low would not have fitted), When I queried it with them they said it would be fine that other guys had this offset. They did come with bolts but they were not long enough to be safe so ended up getting longer bolts to fit on my car.
Good price on the deal but check details carefully to make sure you get what you want.
https://www.tyres-pneus-online.co.uk/car-wheels/borbet/re/8.0x18-5x112-et48-57.1-26.html
These are the set I went for after alot of research. Absolutely perfect fit (I don’t have Brembo brakes however)
Nexen Wintersport 2s all for under £750 fitted balanced and delivered within a week. Oponeo also had a similar deal
All imitations to your True Cupra Carbon R ST![]()
@Damo H has a Carbon ST verging on an R lol
I’ll be surprised if the R ST happens. Seat UK said end of 2018, but they better get a shift onBut it’s not a R ST Carbon though is it!!!
I also own a Carbon Edition Cupra but it’s not an R nor will it ever be
Only difference between a Carbon and the ST R concept:
Carbon fibre spoiler.
Fog less black intakes.
Copper detailing in and out (although the ST R concept had normal white seats if you look closely)
Black Calipers
However mine is now a non copper R. Only thing missing is the Carbon spoiler, for now anyway
