Mines are 39 front 38 back which is correct according to whats stated on the door frame.I’ll go and check mine now as the road noise is quite loud.
The 4 drive ST is:That sounds high - are you looking at the fully loaded pressures?
Is the 32 and 29 just a guess? That's MUCH lower than recommended. The white label with the tyre pressure settings is inside the passengers side door.Mine had 42 psi!! Just dropped to 32psi in the front and 29 in the rear.
No, those are the normal load pressures listed on the label on the door-frame. I was quite surprised because it was quite an increase from the 32 when the car was delivered last week. The fully loaded pressures are over 40.That sounds high - are you looking at the fully loaded pressures?
I've not got that, just the other 2. Strange one that!
Normal speakers IMO are quite good.Are the normal speakers good enough? I’m disappointed that they’ve removed Seat Sound
The difference is night and day you'll be quite happy.That’s not too bad then. Can’t wait for mine to arrive in feb. Moving from a 1.2 corsa to that!
No! I've just got the two options on mine,how strange
Wonder if it’s a Carbon/R thing. My 280 didn’t have it. Wonder if the sub 8/ performance cars have itNo! I've just got the two options on mine,how strange
Got a call from my dealer today that my Midnicht Black ST 300 4Drive is due to arrive on Tuesday. It'll get a fuel operated engine and inroom warmer fitted and probably I'll get a Ceramic coating on it also. Maybe I'll get my hands on it on January 2nd.. It has the digital cockpit, Beats audio, the cup seats and parking sensors front and back. Can't wait.
Hope so, I ordered mine in October but sure the exhaust will keep me acousticaly entertained )) I will try & get the sound actuator turned off though. I posted earlier I have emailed Seat with my feedback on sound system upgrade no longer being available. Sure the normal setup will be ok. That is my gripe, the Cupra should be more than just OK. Hopefully someone at Seat S.A will get a boot up the rear & Beats or SS will become standard or optional once again.Are the normal speakers good enough? I’m disappointed that they’ve removed Seat Sound
