It certainly looks like it. When I bought it, it had H&R springs, trak+ spacers and Milltek catback exhaust. Also, the bottom steering wheel insert is black. Not sure if thats oem, cause all the one's I've seen before are silver.
At least you know it's in good hands lolHAHA!! Don't let me see my old car......I think i'll have too many regrets!!
Yeah that sounds like my car.
I can’t see why they needed to take them off as you leave the hub on the car
Have you got your car back yet ?
Looks stunning mate a credit to youFinally had chance for a clean. Think the ride height is sitting pretty much the same. Although possibly slightly up at the front. Overall, I'm pleased with the coilovers. I mistook them doing nothing with now not noticing loads of small bumps. As above there is an improvement in cornering and I also noticed last night accelerating hard and hitting a bump was a nightmare previously. But the recovery time seems pretty much instant.
It does look as if the front is a little higher than the back but that could just be in the pic
Cars looking super clean as always mate
Looks pretty sweet. I’ll be interested to hear a longer term review of the shocks.
As said, it does seem a little lower at the back, ideally you’d want it the other way round.
Is there anything you don't know or know how to fix lolThe only thing I can suggest is that the coilover setup pushes the wheels back down quicker than your old, I have seen
Coilover Preload
This one I definitely know the least about, but let me try to paint a picture. You hit a bump. Suspension compresses. You finish traveling over bump. Suspension must expand. In fact, before suspension expands, we aren't even really gripping the road. Preload helps push the suspension back to the road, faster. Preload also helps keep springs in place. For preload, I recommend starting per manufacturer specifications. From there, try increasing in small increments if other adjustments aren't working to fix your ride issues.
as seen here https://drivetribe.com/p/suspension...cZ_sQVmThHxU1iBm3g?iid=Uk6whfH3R-ChEHoPYWY2LQ
