So, as some of you may already know from my ramblings on this forum, I’ve recently had a resonator delete fitted to my
Cupra 300 DSG.
The one and only downside I found was that the soundaktor was just making the car far too noisy inside, especially as I have the car permanently in Cupra mode (but with the normal gearbox). This became more apparent when I went on a long motorway trip last weekend.
I stumbled across a few threads regarding the soundaktor, and to my surprise I found out that it is incredibly simple to deactivate without having to go through ODBEleven or similar. I know that this topic has been discussed previously but I thought I’d post a couple of photos just to show how easy it is, in case any of you are in the same boat! Now all I have is the sweet, sweet NATURAL sound of an unresonated exhaust
1. Open the bonnet.
2. Remove the rubber strip at the bottom of the plastic tray underneath the windscreen:
3. Remove the three metal clips which hold the plastic tray in place (I used some needle nose pliers):
4. Pull up the foam stuff (yes, technical term). There are 2 plastic clips which can be insterted back afterwards:
5. Reach under the plastic tray and locate the soundaktor box (it’s in the driver side corner and it says soundaktor on the top!).
6. Pull the connector out of the soundaktor box.
7. Replace the foam, then the three metal clips, then finally the rubber strip.
Congratulations. You now have an interior which doesn’t sound like a PlayStation game every time you put your foot down..!!
Obviously, it’s just as easy to reconnect it should you wish to do so.
I’ve just taken mine for a quick drive and the difference is fantastic. I can still hear the exhaust but it’s out the back, where it should be..! More importantly, it makes absolutely no difference to how the car sounds from the outside
